| buck toenges |
May 12 2020, 04:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 554 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None
If I put 2 gallons of fuel in my gas tank nothing leaks. When I put 12 gallons in it leaks. It drips from the bottom. I took out the tank and changed out the hoses from tank to ss fuel lines. I assumed I hadn't tighten the fuel hoses properly. I am using FI hose clamps. I even changed out a fuel pipe from the tank to make sure I had the bigger 9mm(10)mm fuel pipe on the one side of the fuel tank. When I put in 2 gallons no leaks. When I filled up the tank and drove for 20 minutes and parked I got a big gas puddle under the car.
Could I have a leak somewhere else on the fuel tank other then where the fuel hoses connect? Is there pressure from the FI system that may be pressurizing the tank too much? Any thoughts? I am thinking about getting a new Dansk fuel tank. I see them listed as 1974-1976. Will they work for a '72 car? Who has the best price for these new repro tanks. Thanks, Buck |
| ClayPerrine |
May 13 2020, 11:36 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
If I put 2 gallons of fuel in my gas tank nothing leaks. When I put 12 gallons in it leaks. It drips from the bottom. I took out the tank and changed out the hoses from tank to ss fuel lines. I assumed I hadn't tighten the fuel hoses properly. I am using FI hose clamps. I even changed out a fuel pipe from the tank to make sure I had the bigger 9mm(10)mm fuel pipe on the one side of the fuel tank. When I put in 2 gallons no leaks. When I filled up the tank and drove for 20 minutes and parked I got a big gas puddle under the car. Could I have a leak somewhere else on the fuel tank other then where the fuel hoses connect? Is there pressure from the FI system that may be pressurizing the tank too much? Any thoughts? I am thinking about getting a new Dansk fuel tank. I see them listed as 1974-1976. Will they work for a '72 car? Who has the best price for these new repro tanks. Thanks, Buck Buck, I have been there, done that. Check the tank where it rests on the carpet pads. Those pads trap water and rust the tank. Eventually, it will get to the point that the gas will seep through the porous metal where the carpet pads are located. All you can do is install a replacement tank. Clay |
| mepstein |
May 13 2020, 11:58 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,662 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Common problem on these 50 year old cars.
| brant |
May 13 2020, 12:02 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,183 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
tank is rusted out.
the rust hole is high enough up the side (at the carpet pads likely) that it takes 12 gallons to bring the fuel level up to the rust hole. you'll need a new tank expensive to ship... best to find something local |
| Superhawk996 |
May 13 2020, 12:09 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,825 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
All you can do is install a replacement tank. Clay Are you kidding? You haven't lived until you've welded on a gas tank! (IMG:style_emoticons/default/tooth.gif) You may only live for a few seconds if you fail to prep it properly. It can be done. I've done it on motorcycle tanks and know those that have done it on vintage car gas tanks. However, given the ready supply of good 914 tanks both in new and donor form, Clay is right - replacment is the better option. |
| jfort |
May 13 2020, 12:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,189 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest
been there. i had a shop weld on it. didn't get cleaned well enough after the repair. my fault. but i got tired of cleaning out my idle jets and bought a new tank at Stoddards. Very reasonable I thought. Should have just done that in the first place.
| Jamie |
May 13 2020, 12:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,204 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
Yes, buy a new tank. I had one cleaned out and coated, later found I could have bought a new tank for less than the cost of repairs, which removed all the attachment mounts for the charcoal canister and expansion tank
Lo-Fi Version | Time is now: 30th April 2026 - 07:06 AM |
