car wont start after hot, mystery problem |
Dmidco914 |
May 16 2020, 04:20 PM
Newbie Group: Members Posts: 5 Joined: 16-May 20 From: winter garden fl Member No.: 24,271 Region Association: South East States |
1974 1.8 original car dual carbs. After it is used for one to two hours the car will not start. I let it sit and it works fine. Last time all my gauges went dead and the car died. including radio, fuel gauge and volt meter gauge. I have replaced the key switch and the ignition switch, also new starter and battery. relays are all good and seem to work. any ideas?
914_7T3 |
May 16 2020, 04:28 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
See @Mark Henry ‘s solution here http://www.914world.com/bbs2/index.php?showtopic=308904 |
KELTY360 |
May 16 2020, 04:33 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Check your battery cable. May be corroded inside insulation where you can’t see it. If it’s hot it will increase resistance from battery.
Mark Henry |
May 17 2020, 10:42 AM
1974 1.8 original car dual carbs. After it is used for one to two hours the car will not start. I let it sit and it works fine. Last time all my gauges went dead and the car died. including radio, fuel gauge and volt meter gauge. I have replaced the key switch and the ignition switch, also new starter and battery. relays are all good and seem to work. any ideas? Although the first part suggests a hot start issue, the passage in bold is some kind of ground issue to me, my ford solenoid fix won't fix a ground issue. What it helps with is resistance in the old wiring, multiple connections, switch and relays and the resulting drop in voltage to the Bosch starter solenoid. Check and clean your tranny ground strap, battery terminal connections, ground cable body lug, engine harness ground lug (below relay console), etc. If still having issues then you have to start tracing the wiring. Also spin all your fuses in the fuse block, sometimes (often) the holders corrode enough to cause connectivity issues. After all the wiring and grounds are sorted if you still have a hot start issue then my fix may help you. |
Ansbacher |
May 17 2020, 11:26 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Flaky alternator, maybe..??..
Ansbacher |
yellowporky |
May 17 2020, 09:28 PM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
My first 914 had dual carbs and suffered this same thing.
From what I was told was that when the fuel injection is removed so are some of the grounds and the fix was to add another engine to body ground. I did this from where the battery negative attaches to the body and to An open bolt hole on the fan shroud. It solved my issue. This is cheap and easy so I hope it helps Chris |
Dmidco914 |
May 18 2020, 10:21 AM
1974 1.8 original car dual carbs. After it is used for one to two hours the car will not start. I let it sit and it works fine. Last time all my gauges went dead and the car died. including radio, fuel gauge and volt meter gauge. I have replaced the key switch and the ignition switch, also new starter and battery. relays are all good and seem to work. any ideas? Thanks everybody. |
VaccaRabite |
May 18 2020, 10:39 AM
1974 1.8 original car dual carbs. After it is used for one to two hours the car will not start. I let it sit and it works fine. Last time all my gauges went dead and the car died. including radio, fuel gauge and volt meter gauge. I have replaced the key switch and the ignition switch, also new starter and battery. relays are all good and seem to work. any ideas? Thanks everybody. Still add a solinoid to remove the strain and voltage drop from all the starting current going through the ignition switch. This was a stupid design from the factory and should never have been made this way. (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/bs.gif) Zach |
MartyYeoman |
May 18 2020, 11:21 AM
Senior Member Group: Members Posts: 1,518 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Lo-Fi Version | Time is now: 14th May 2024 - 05:42 AM |
