Pedal cluster stud, Pitch? |
trojanhorsepower |
May 17 2020, 10:48 AM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So the two studs that stick up out of the floor and go through the base of the pedal cluster plate seem to be a odd pitch. Does anyone know what they are? As far as I can figure they are not 8-1, 8-1.25, 9-1 or 9-1.25. Seems like something in between. These are the only taps I have in this range so I can not test any more. I have one nut that fits and it has a washer attached. Are these special nuts with special threads or am I just missing something obvious.
Thanks, Peter |
Superhawk996 |
May 17 2020, 10:51 AM
914 Guru Group: Members Posts: 5,816 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Get a thread pitch gauge. Actually two - one metric - one SAE Very affordable on Amazon and anwers these questions.
On car's this old, you can't necessarily assume its metric. Inspect carefully, you may find someone has put in a SAE stud. They were prone to corrosion and shearing off. P.S. They are M8x1.25. The nut with an attached washere is not OEM so signs lead to someone having messed with it before. |
cary |
May 17 2020, 10:59 AM
914werke |
May 17 2020, 11:12 AM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
they should be M8x1,25 that are attached to the pedal support bracket that protrudes through the floor pan, check from below to see if its been messed with
sixnotfour |
May 17 2020, 11:31 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
5/16-18 jf someone americanized it
trojanhorsepower |
May 17 2020, 07:15 PM
Yup. M8 - 1.25. Just had a bunch of junk on the threads and for some reason this weird nut happened to fit on the thread mess.
Thanks All! |
Lo-Fi Version | Time is now: 15th May 2024 - 04:35 AM |
