930 shifting?, How does your shifting work? |
MikeP |
Jul 8 2005, 03:13 PM
Member Group: Members Posts: 321 Joined: 13-June 05 From: San Jose, CA Member No.: 4,268 |
I'm weighing Trans options for my v8 right now and I'm hearing that the 930 shifts like (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif)
Anybody have experience with them? |
ArtechnikA |
Jul 8 2005, 03:17 PM
the only detrimental thing i've heard is that since it is a 4-speed the gates are not well defined, and there are not a lot of aftermarket "spring-centering" shifters (like the RennShift) available for them.
but i've never driven one, so i can't say for sure. |
john rogers |
Jul 8 2005, 05:35 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
We own a 1987 930 and I learned to shift it slow and easy since it was designed for lots of power but not a lot of speed. My 901 in the race car shifts better, but it can't handle 400 or more HP!
BIGKAT_83 |
Jul 8 2005, 07:34 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
These people are working on transaxles for the street mid engine after market (pantras and kit cars) They don't have any listed on the website,but will be making a 5 speed for the street.
Better start saving because it will be expensive. TRANSAXLE Bob |
John |
Jul 8 2005, 09:58 PM
I may just be used to it, but my stock 1983 930 shifts just fine.
1st gear is sometimes tough to get into unless the car is stopped. I just be gentle while shifting the gears and it does well. If you try FORCING it, the car does not shift well. If you take your time and use only moderate pressure, it shifts very well. I have never shifted a 930 transmission modified for use in a 914. |
nine14cats |
Jul 9 2005, 11:32 AM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Hi Mike,
I had a 1988 930 that had the 4 speed in it. I swapped it for a 915 to shorten the ratios for the street!...... Anyway...the 930 I had was pretty easy to shift, except for getting it into first. Normally I had to double clutch it. In my opinion, it was fine to shift, but not as quick as the 915 or 901. Gear ratio wise, the RH 901 tall unit I have for JLO is almost identical in gearing to the 930 box. As far as linkage, RH and Jerry Woods likes to use a cable set up, while Rod Simpson has a low cost linkage that is very similar to the factory tail shift 901 linkage. I've talked to Rod about it and he likes the his low cost solution utilizing the shift rod versus a cable. Thanks, Bill P. |
Lo-Fi Version | Time is now: 21st May 2024 - 12:54 AM |
