6 stud heads - what options exist and what head’s can be made to work? |
Tdskip |
May 18 2020, 06:39 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
The 2.7L big Type 4 had/had funky heads on it that were customized for the 6 stud case.
Can you do that with 1.8 or 2.0L 914 heads as well? Anyone been there, done that, figured it out? Thanks and hope Monday has been a good one. |
Superhawk996 |
May 19 2020, 05:57 AM
914 Guru Group: Members Posts: 5,812 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
The 2.7L big Type 4 had/had funky heads on it that were customized for the 6 stud case. Can you do that with 1.8 or 2.0L 914 heads as well? Anyone been there, done that, figured it out? Thanks and hope Monday has been a good one. You can do anthing with enought time and money. That engine seems to be a unicorn. I suspect that someone esentially built a one off science project. From what I've seen so far it seems like some one spent a bunch of time a money on it already. Is there a reason you can't simply rebuild those heads? |
Tdskip |
May 19 2020, 06:01 AM
Good morning and thanks for the response.
I was asking mainly to see if I could use 2.0L to get more stock exhaust. Basically making it less unicorn. Grin. |
bdstone914 |
May 19 2020, 06:17 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Tdskip
' date='May 19 2020, 05:01 AM' post='2816774'] Good morning and thanks for the response. I was asking mainly to see if I could use 2.0L to get more stock exhaust. Basically making it less unicorn. Grin. [/quote] You can bolt any exhaust to any 914 head. (IMG:style_emoticons/default/confused24.gif) |
Tdskip |
May 19 2020, 07:11 AM
Hi Bruce - this engine has some sort of customized non-Type4 head. Attached thumbnail(s) |
bdstone914 |
May 19 2020, 08:13 AM
That is the intake. What do the exhaust ports look like? If modified you probably cant adapt a stock type exhaust. And if you do it may restrict the breathing of the engine.
Tdskip |
May 19 2020, 11:36 AM
The heads that came with it have bigger valves than Tyep 4 heads, 40 and 48 which is pretty significant than even the upgraded 2.0L heads.
Lo-Fi Version | Time is now: 14th May 2024 - 09:07 AM |
