wanted shift rod head 91442424102, as many as you have |
dr914@autoatlanta.com |
May 19 2020, 04:12 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
paying 40 each delivered
JamesM |
Dec 26 2020, 03:14 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
When i replaced the linkage on my vanagon i noticed it uses a very similar part, though the set screw is 90deg rotated from the 914 part. I will have to look at my old one and compare dimensions.
These are also being made in billet currently as well, looks like a fairly cheap part to repro. https://www.gowesty.com/product/manual/2476...tor-lever-elbow https://www.vancafe.com/251711973-AFT-p/251711973-aft.htm https://www.gowesty.com/product-details.php...gory_parent_id= |
bdstone914 |
Jan 22 2021, 03:27 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
When i replaced the linkage on my vanagon i noticed it uses a very similar part, though the set screw is 90deg rotated from the 914 part. I will have to look at my old one and compare dimensions. These are also being made in billet currently as well, looks like a fairly cheap part to repro. https://www.gowesty.com/product/manual/2476...tor-lever-elbow https://www.vancafe.com/251711973-AFT-p/251711973-aft.htm https://www.gowesty.com/product-details.php...gory_parent_id= Those are similar but look longer. I am making a few by starting with the shift part for the rail shift and welding on a 10mm extension. @JamesM Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:42 AM |
