How often do you replace your clutch cable? |
RickS |
May 20 2020, 09:09 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
My throw is starting to feel notchy again, which means it’s time to replace yet again. In 15 years this will be #6. I know Mark was looking at offering a better one but never saw the upshot.
So how often do you replace yours? It would sure be nice if they were self adjusting like old shoe type brakes. |
mountainroads |
May 20 2020, 10:16 PM
Member Group: Members Posts: 210 Joined: 19-February 12 From: Seattle Member No.: 14,145 Region Association: Pacific Northwest |
My throw is starting to feel notchy again, which means it’s time to replace yet again. In 15 years this will be #6. I know Mark was looking at offering a better one but never saw the upshot. So how often do you replace yours? It would sure be nice if they were self adjusting like old shoe type brakes. I've personally experienced a cable failure while on the road, so regular inspection is warranted and would personally suggest replacement after a couple of adjustments due to cable stretch, or major service such as a clutch replacement. Check for wear and frayed cable wires at the wheel where the cable does a u-turn, since that area is exposed and subject to twisting stresses. Relatively cheap and easy part to replace so it doesn't leave you stranded. I was lucky: cable snapped while I was shifting from 4th into 3rd. A bit of an adventure getting home the 70+ miles without shifting, including two unavoidable small towns with several stop lights. Blew a stop sign right in front of the local police station to avoid one of the red lights (IMG:style_emoticons/default/smile.gif). 3rd was the only gear that I could make it all the way home without unduly lugging or over revving the engine, or running out of gas. - MR ' |
RickS |
May 20 2020, 11:31 PM
My throw is starting to feel notchy again, which means it’s time to replace yet again. In 15 years this will be #6. I know Mark was looking at offering a better one but never saw the upshot. So how often do you replace yours? It would sure be nice if they were self adjusting like old shoe type brakes. I've personally experienced a cable failure while on the road, so regular inspection is warranted and would personally suggest replacement after a couple of adjustments due to cable stretch, or major service such as a clutch replacement. Check for wear and frayed cable wires at the wheel where the cable does a u-turn, since that area is exposed and subject to twisting stresses. Relatively cheap and easy part to replace so it doesn't leave you stranded. I was lucky: cable snapped while I was shifting from 4th into 3rd. A bit of an adventure getting home the 70+ miles without shifting, including two unavoidable small towns with several stop lights. Blew a stop sign right in front of the local police station to avoid one of the red lights (IMG:style_emoticons/default/smile.gif). 3rd was the only gear that I could make it all the way home without unduly lugging or over revving the engine, or running out of gas. - MR ' I always carry a spare, just in case. A friend said he can install a mechanical linkage and be rid of the cable but is an expensive mod. I like Calvin’s solution and will try that. |
Lo-Fi Version | Time is now: 3rd May 2024 - 10:39 AM |
