How often do you replace your clutch cable? |
RickS |
May 20 2020, 09:09 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
My throw is starting to feel notchy again, which means it’s time to replace yet again. In 15 years this will be #6. I know Mark was looking at offering a better one but never saw the upshot.
So how often do you replace yours? It would sure be nice if they were self adjusting like old shoe type brakes. |
mountainroads |
May 20 2020, 10:16 PM
Member Group: Members Posts: 210 Joined: 19-February 12 From: Seattle Member No.: 14,145 Region Association: Pacific Northwest |
My throw is starting to feel notchy again, which means it’s time to replace yet again. In 15 years this will be #6. I know Mark was looking at offering a better one but never saw the upshot. So how often do you replace yours? It would sure be nice if they were self adjusting like old shoe type brakes. I've personally experienced a cable failure while on the road, so regular inspection is warranted and would personally suggest replacement after a couple of adjustments due to cable stretch, or major service such as a clutch replacement. Check for wear and frayed cable wires at the wheel where the cable does a u-turn, since that area is exposed and subject to twisting stresses. Relatively cheap and easy part to replace so it doesn't leave you stranded. I was lucky: cable snapped while I was shifting from 4th into 3rd. A bit of an adventure getting home the 70+ miles without shifting, including two unavoidable small towns with several stop lights. Blew a stop sign right in front of the local police station to avoid one of the red lights (IMG:style_emoticons/default/smile.gif). 3rd was the only gear that I could make it all the way home without unduly lugging or over revving the engine, or running out of gas. - MR ' |
ClayPerrine |
May 21 2020, 03:01 PM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I've personally experienced a cable failure while on the road, so regular inspection is warranted and would personally suggest replacement after a couple of adjustments due to cable stretch, or major service such as a clutch replacement. Check for wear and frayed cable wires at the wheel where the cable does a u-turn, since that area is exposed and subject to twisting stresses. Relatively cheap and easy part to replace so it doesn't leave you stranded. I was lucky: cable snapped while I was shifting from 4th into 3rd. A bit of an adventure getting home the 70+ miles without shifting, including two unavoidable small towns with several stop lights. Blew a stop sign right in front of the local police station to avoid one of the red lights (IMG:style_emoticons/default/smile.gif). 3rd was the only gear that I could make it all the way home without unduly lugging or over revving the engine, or running out of gas. - MR ' You don't have to leave it in one gear. If you are careful with the shifter, you can start the engine at a light in first gear, and use RPM matching to get all the way up through the gears. You can do the same downshifting. But you have to blip the throttle and keep some pressure on the gear lever. When the RPMs match between the gear and the shaft, it will slip into gear. Drove all the way back to the hotel in Vonore TN from the tail of the dragon with a broken clutch cable. The only problem was getting started at a light or stop sign. I got really adept at not coming to a complete stop for traffic lights. |
mountainroads |
May 21 2020, 03:34 PM
You don't have to leave it in one gear. If you are careful with the shifter, you can start the engine at a light in first gear, and use RPM matching to get all the way up through the gears. You can do the same downshifting. But you have to blip the throttle and keep some pressure on the gear lever. When the RPMs match between the gear and the shaft, it will slip into gear. Drove all the way back to the hotel in Vonore TN from the tail of the dragon with a broken clutch cable. The only problem was getting started at a light or stop sign. I got really adept at not coming to a complete stop for traffic lights. Yeah, I thought about resorting to double clutching if I absolutely had to, but I was making good progress w/o stopping. Although very familiar with manuals since I learned on one, I was 19 yo at the time and had only experimented with said technique a couple of times . I was afraid I'd either ruin the synchros or never get the car back into gear, so I just kept going. Was golden once I got to the freeway and the -6 engine seemed reasonably happy at 60 mph in 3rd. - MR |
Lo-Fi Version | Time is now: 30th April 2024 - 09:35 AM |
