GB -Thresholds and carpet strips (black in aluminum NOT plastic), GB is on will include all screws and push rivets needed to install. |
Mikey914 |
May 25 2020, 08:11 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You know me, if I'm in a position to save you all some money, I'll pass it on.
We are doing another large run of the thresholds and carpet strips. The "chrome" is an anodized finish so they will not dull. The black are not like the factory part in that it was plastic. This is especially annoying in that the carpet strips sag when you tighten down the screws. The aluminum does not do this. We hard coat anodize these with the black dye so that they are extremely difficult to scratch. In fact it had an aluminum oxide "shell" that keeps it from scratching. I'm looking at doing a kit that includes the push rivets and screws (black nickel coated for the black sills) Would need 10 takers of each flavor. and would be at least $60 off, more if we get more takers, the silver could be even more as the finishing costs are less. Who's interested? |
Mikey914 |
Jun 27 2020, 10:34 AM
Nope -
Codes sent to all so far The GB code will close out Sunday Midnight Pacific time Still some time left (IMG:style_emoticons/default/biggrin.gif) I'm most proud of the Black Nickel plated screws, they turned out nice. The problem with black zinc was there was galvanic corrosion and the would oxidize making a white chalk. These will not. |
dakotaewing |
Jun 27 2020, 01:08 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Nope - Codes sent to all so far The GB code will close out Sunday Midnight Pacific time Still some time left (IMG:style_emoticons/default/biggrin.gif) I'm most proud of the Black Nickel plated screws, they turned out nice. The problem with black zinc was there was galvanic corrosion and the would oxidize making a white chalk. These will not. @Mikey914 Don't know how I missed this - I'll need a (1) set, but have not made up my mind which one. Mark can you send me the codes, and I'll get mt order in before it ends? Thanks - Thom |
Lo-Fi Version | Time is now: 1st May 2024 - 10:39 PM |
