Oil leak repair |
Oil leak repair |
FJ1200 |
May 30 2020, 08:28 AM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings,
Fairly new to the forums and owner of a 1972 teener. I bought the car last spring with a slightly hot rodded 2.0 and a side shift conversion. The true upside is ZERO rust, I have a lift and have inspected every inch of the car. The issue I have is that the oil filter flange is leaking badly (1qt/20 miles). Upon inspection it appears that the upper nut can not be removed without removing the oil cooler. I have new oil cooler seals and the oil filter flange gasket coming from Auto Atlanta. Question is, has anyone ever removed the filter flange in the car? I really would rather not perform an engine drop this week, but I will if needed. Just a little background, until 5 yrs ago I was an Audi dealer shop foreman for 25 years. As a result the nuts and bolts don't bother me at all. It is more current time constraints and the want to drive the car. Thanks, Daniel |
North Coast Jim |
May 30 2020, 10:07 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Buy the Harbor Freight hydraulic lift table. The 800 lb version. It will support both the engine and tranny. Easy peasey. You just need to get the car up in height far enough. Thought I read you had a lift so all is good. I can do my carb'd engine in 1 hr 45 min. Just did it a week ago.
Lo-Fi Version | Time is now: 26th May 2024 - 02:36 AM |
