Oil leak repair |
Oil leak repair |
FJ1200 |
May 30 2020, 08:28 AM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings,
Fairly new to the forums and owner of a 1972 teener. I bought the car last spring with a slightly hot rodded 2.0 and a side shift conversion. The true upside is ZERO rust, I have a lift and have inspected every inch of the car. The issue I have is that the oil filter flange is leaking badly (1qt/20 miles). Upon inspection it appears that the upper nut can not be removed without removing the oil cooler. I have new oil cooler seals and the oil filter flange gasket coming from Auto Atlanta. Question is, has anyone ever removed the filter flange in the car? I really would rather not perform an engine drop this week, but I will if needed. Just a little background, until 5 yrs ago I was an Audi dealer shop foreman for 25 years. As a result the nuts and bolts don't bother me at all. It is more current time constraints and the want to drive the car. Thanks, Daniel |
FJ1200 |
Jun 2 2020, 05:33 PM
Miracle of all miracles, all of the oil stays in the engine (for the most part). I replaced the oil filter flange gasket and resealed the oil cooler. Checked the valves while it was out and tidied up the engine bay a bit. The fuel lines were looking pretty ragged, so I replaced them with modern German hose rated for ethanol fuels. Took it for a 20 mile road test and not a drop in sight.
Thanks for any input. Daniel |
Lo-Fi Version | Time is now: 18th May 2024 - 07:30 PM |
