Oil leak repair |
Oil leak repair |
FJ1200 |
May 30 2020, 08:28 AM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings,
Fairly new to the forums and owner of a 1972 teener. I bought the car last spring with a slightly hot rodded 2.0 and a side shift conversion. The true upside is ZERO rust, I have a lift and have inspected every inch of the car. The issue I have is that the oil filter flange is leaking badly (1qt/20 miles). Upon inspection it appears that the upper nut can not be removed without removing the oil cooler. I have new oil cooler seals and the oil filter flange gasket coming from Auto Atlanta. Question is, has anyone ever removed the filter flange in the car? I really would rather not perform an engine drop this week, but I will if needed. Just a little background, until 5 yrs ago I was an Audi dealer shop foreman for 25 years. As a result the nuts and bolts don't bother me at all. It is more current time constraints and the want to drive the car. Thanks, Daniel |
Dave_Darling |
Feb 8 2023, 09:00 PM
There's at least a decent chance that much of your oil is coming from those seals that have the extra goop on them.
Hopefully that's not a crack I see where the oil pressure sender threads in. --DD |
Lo-Fi Version | Time is now: 18th May 2024 - 07:49 PM |
