Oil leak repair |
Oil leak repair |
FJ1200 |
May 30 2020, 08:28 AM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings,
Fairly new to the forums and owner of a 1972 teener. I bought the car last spring with a slightly hot rodded 2.0 and a side shift conversion. The true upside is ZERO rust, I have a lift and have inspected every inch of the car. The issue I have is that the oil filter flange is leaking badly (1qt/20 miles). Upon inspection it appears that the upper nut can not be removed without removing the oil cooler. I have new oil cooler seals and the oil filter flange gasket coming from Auto Atlanta. Question is, has anyone ever removed the filter flange in the car? I really would rather not perform an engine drop this week, but I will if needed. Just a little background, until 5 yrs ago I was an Audi dealer shop foreman for 25 years. As a result the nuts and bolts don't bother me at all. It is more current time constraints and the want to drive the car. Thanks, Daniel |
930cabman |
Feb 10 2023, 07:21 PM
Advanced Member Group: Members Posts: 3,095 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I was chasing an oil leak at the front end and found one at one of the oil galley plugs, could see it seeping while the engine was running. Got her fixed but still have a bit leaking from the front end.
How many do NOT leak? |
Superhawk996 |
Feb 10 2023, 08:24 PM
914 Guru Group: Members Posts: 5,859 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I was chasing an oil leak at the front end and found one at one of the oil galley plugs, could see it seeping while the engine was running. Got her fixed but still have a bit leaking from the front end. How many do NOT leak? @930cabman Many rebuilds are sealed with steel plugs. Difference in thermal expansion between aluminum case and steel plug doesn’t help. Factory used aluminum plugs for a reason. |
Lo-Fi Version | Time is now: 26th May 2024 - 11:44 AM |
