Oil leak repair |
Oil leak repair |
FJ1200 |
May 30 2020, 08:28 AM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings,
Fairly new to the forums and owner of a 1972 teener. I bought the car last spring with a slightly hot rodded 2.0 and a side shift conversion. The true upside is ZERO rust, I have a lift and have inspected every inch of the car. The issue I have is that the oil filter flange is leaking badly (1qt/20 miles). Upon inspection it appears that the upper nut can not be removed without removing the oil cooler. I have new oil cooler seals and the oil filter flange gasket coming from Auto Atlanta. Question is, has anyone ever removed the filter flange in the car? I really would rather not perform an engine drop this week, but I will if needed. Just a little background, until 5 yrs ago I was an Audi dealer shop foreman for 25 years. As a result the nuts and bolts don't bother me at all. It is more current time constraints and the want to drive the car. Thanks, Daniel |
Superhawk996 |
Feb 9 2023, 09:06 AM
914 Guru Group: Members Posts: 5,860 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Someone else just went through a similar leak with puddling on top of the oil filter.
Problem was oil filter was not properly tightened. Simple mistake. Same thing going on here? |
Morrie |
Feb 9 2023, 02:19 PM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
Someone else just went through a similar leak with puddling on top of the oil filter. Problem was oil filter was not properly tightened. Simple mistake. Same thing going on here? That was my first thought (hope) but the filter is snug and this has been leaking over the course of several oil filter changes. I do have a couple spare filter stands. I am going to look very closely for defects on the sealing bead on the casting where it meets the filter, just to be sure. You don't think that a stuck oil pressure relief valve pushing oil past the filter seal could be at fault? I hate to pull them if there is little to no chance but if someone thinks it is possible I will. Would you pull all those threaded galley plugs and reseal them? If so, what sealant would you use? Sorry for all the dumb questions. Try not to be too hard on me. I've rebuilt 616 engines with no leaks so I know it is possible, but the galley plugs we use on those are press in replacements. |
bkrantz |
Feb 9 2023, 08:33 PM
914 Guru Group: Members Posts: 7,774 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Someone else just went through a similar leak with puddling on top of the oil filter. Problem was oil filter was not properly tightened. Simple mistake. Same thing going on here? That was my first thought (hope) but the filter is snug and this has been leaking over the course of several oil filter changes. I do have a couple spare filter stands. I am going to look very closely for defects on the sealing bead on the casting where it meets the filter, just to be sure. You don't think that a stuck oil pressure relief valve pushing oil past the filter seal could be at fault? I hate to pull them if there is little to no chance but if someone thinks it is possible I will. Would you pull all those threaded galley plugs and reseal them? If so, what sealant would you use? Sorry for all the dumb questions. Try not to be too hard on me. I've rebuilt 616 engines with no leaks so I know it is possible, but the galley plugs we use on those are press in replacements. That was me. I HOPE most of the oil that leaked on mine came out of the filter, but I have changed some other things, too. I would not pull the galley plugs unless you have some evidence that one is leaking. I sympathize with your struggle. (IMG:style_emoticons/default/headbang.gif) |
Superhawk996 |
Feb 9 2023, 09:00 PM
bkrantz |
Feb 10 2023, 08:28 PM
I appreciate it. But like I said in my oil leak thread, I have no shame--I would rather get rid of the leak. |
Lo-Fi Version | Time is now: 26th May 2024 - 05:56 PM |
