Blocking off or stripping the shell from heat exchangers where you’re not going to use heat |
Tdskip |
Jun 1 2020, 10:25 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning. I was going through some past notes and @bdatone914 made the suggestion of either blocking off where the heat would be connected or just stripping the shell off the actual exhaust part of the heat exchanger on a car that would not be using heat.
Is it better to take one approach versus the other? I would imagine stripping the shell off the actual exhaust would allow everything to stay a bit cooler, but not sure if there’s any shielding that makes sense to leave in place to help the engine stay cool. Hope everybody had a good weekend. |
mlindner |
Jun 1 2020, 10:39 AM
Senior Member Group: Members Posts: 1,523 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Tdship, I took mine off many years ago, cleaned up the header portion and they work great 10 until engine was pulled. My outer shell/heat exchangers were pretty rusty, header pipes them selves were good. best, Mark
Lo-Fi Version | Time is now: 27th May 2024 - 08:51 AM |
