Blocking off or stripping the shell from heat exchangers where you’re not going to use heat |
Tdskip |
Jun 1 2020, 10:25 AM
Good morning. I was going through some past notes and @bdatone914 made the suggestion of either blocking off where the heat would be connected or just stripping the shell off the actual exhaust part of the heat exchanger on a car that would not be using heat.
Is it better to take one approach versus the other? I would imagine stripping the shell off the actual exhaust would allow everything to stay a bit cooler, but not sure if there’s any shielding that makes sense to leave in place to help the engine stay cool. Hope everybody had a good weekend. |
IronHillRestorations |
Jun 1 2020, 12:01 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'd take off the heater branch pieces and block off the air outlets at the bottom of the impeller housing as well
Lo-Fi Version | Time is now: 6th May 2024 - 09:12 AM |
