Mallory parts search |
colingreene |
May 9 2021, 09:45 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Car still being problematic. it dies at idle.
its like someone turned the ignition off. I can see the timing light go out. I also used a test light to confirm that i have constant power to the coil. Really not sure what to do. Im going to take nditiz1 up on his offer to test with his distributor though. |
MarkV |
May 9 2021, 11:42 PM
There are lots of Mallory parts available on Ebay:
https://www.ebay.com/sch/i.html?_from=R40&a...ts&_sacat=0 Not sure why you go that route... they are great distributors buy cars haven't had points since like 1975 for a reason... high maintenance, take some free advice and ditch the points. They also make a low .6 ohm coil to replace the weak bosch factory coil. https://www.ebay.com/itm/380369650854?mkrid...t=1&mkcid=1 (IMG:style_emoticons/default/popcorn[1].gif) |
Mark Henry |
May 10 2021, 07:55 AM
Car still being problematic. it dies at idle. its like someone turned the ignition off. I can see the timing light go out. I also used a test light to confirm that i have constant power to the coil. Really not sure what to do. Im going to take nditiz1 up on his offer to test with his distributor though. Are you 100% positive you don't have a vacuum leak. Engine runs but will not idle is a classic vacuum leak or bent valve symptom. |
colingreene |
May 14 2021, 06:01 PM
Car still being problematic. it dies at idle. its like someone turned the ignition off. I can see the timing light go out. I also used a test light to confirm that i have constant power to the coil. Really not sure what to do. Im going to take nditiz1 up on his offer to test with his distributor though. Are you 100% positive you don't have a vacuum leak. Engine runs but will not idle is a classic vacuum leak or bent valve symptom. It idles fine, it just loses spark and dies, I can see the flash go out on the timing light and then as a result of that it stops. https://www.youtube.com/watch?v=lFO2LB4ZLyk |
Mark Henry |
May 14 2021, 06:53 PM
That sounds like a ground issue, got to admit I'm at a loss, every Mallory I've done I've installed a pertonix or uni-light.
euro911 |
May 14 2021, 07:24 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Check to make sure the grounding strap inside the dizzy is solidly attached at both ends.
Also check your main grounding strap connections at the transaxle (IMG:style_emoticons/default/confused24.gif) |
colingreene |
May 28 2021, 12:57 PM
Ill check the distributor,
I did use a big jumper cable to clip onto the transaxle and go direct to the battery ground. no change so I think that eliminates that possibility. |
Lo-Fi Version | Time is now: 3rd June 2024 - 07:33 AM |
