front trunk seal, replacing |
hndyhrr |
Jun 5 2020, 07:35 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
Hi,
I am going to replace the front trunk seal in a day or two, gotta clean up the old glue in that channel. What kind of glue or snot should i use to re install it. Thanks Renee (IMG:style_emoticons/default/biggrin.gif) |
eric9144 |
Jun 5 2020, 09:00 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I believed no gluing or anything adhesive needed. (IMG:style_emoticons/default/agree.gif) the 914rubber re-pop of the front seal is so good you don't need adhesive. That way if you drive in rain or do a big wash on the car you can pull it up and dry out the channels that water always collects in. |
mb911 |
Jun 6 2020, 06:53 AM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I believed no gluing or anything adhesive needed. (IMG:style_emoticons/default/agree.gif) the 914rubber re-pop of the front seal is so good you don't need adhesive. That way if you drive in rain or do a big wash on the car you can pull it up and dry out the channels that water always collects in. I actually have the opposite experience.. My 914 rubber seal doesn't fit properly and will have to be glued down. |
Matty900 |
Jun 6 2020, 07:18 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
I believed no gluing or anything adhesive needed. (IMG:style_emoticons/default/agree.gif) the 914rubber re-pop of the front seal is so good you don't need adhesive. That way if you drive in rain or do a big wash on the car you can pull it up and dry out the channels that water always collects in. I actually have the opposite experience.. My 914 rubber seal doesn't fit properly and will have to be glued down. We will replace it if there is an issue with it I like to use just a little bit of weather strip adhesive at the corners but don't go nits with it. I just spent hours cleaning the prior owners mess he made on my orange car. Here is Mark showing how to do it at Okteenerfest last year https://www.dropbox.com/s/qmf2dwvzicwfg6t/9...nstall.mp4?dl=0 (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 11:15 PM |
