front trunk seal, replacing |
hndyhrr |
Jun 5 2020, 07:35 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
Hi,
I am going to replace the front trunk seal in a day or two, gotta clean up the old glue in that channel. What kind of glue or snot should i use to re install it. Thanks Renee (IMG:style_emoticons/default/biggrin.gif) |
eric9144 |
Jun 5 2020, 09:00 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I believed no gluing or anything adhesive needed. (IMG:style_emoticons/default/agree.gif) the 914rubber re-pop of the front seal is so good you don't need adhesive. That way if you drive in rain or do a big wash on the car you can pull it up and dry out the channels that water always collects in. |
mb911 |
Jun 6 2020, 06:53 AM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I believed no gluing or anything adhesive needed. (IMG:style_emoticons/default/agree.gif) the 914rubber re-pop of the front seal is so good you don't need adhesive. That way if you drive in rain or do a big wash on the car you can pull it up and dry out the channels that water always collects in. I actually have the opposite experience.. My 914 rubber seal doesn't fit properly and will have to be glued down. |
Matty900 |
Jun 6 2020, 07:18 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
I believed no gluing or anything adhesive needed. (IMG:style_emoticons/default/agree.gif) the 914rubber re-pop of the front seal is so good you don't need adhesive. That way if you drive in rain or do a big wash on the car you can pull it up and dry out the channels that water always collects in. I actually have the opposite experience.. My 914 rubber seal doesn't fit properly and will have to be glued down. We will replace it if there is an issue with it I like to use just a little bit of weather strip adhesive at the corners but don't go nits with it. I just spent hours cleaning the prior owners mess he made on my orange car. Here is Mark showing how to do it at Okteenerfest last year https://www.dropbox.com/s/qmf2dwvzicwfg6t/9...nstall.mp4?dl=0 (IMG:style_emoticons/default/beerchug.gif) |
mb911 |
Jun 6 2020, 07:34 AM
I believed no gluing or anything adhesive needed. (IMG:style_emoticons/default/agree.gif) the 914rubber re-pop of the front seal is so good you don't need adhesive. That way if you drive in rain or do a big wash on the car you can pull it up and dry out the channels that water always collects in. I actually have the opposite experience.. My 914 rubber seal doesn't fit properly and will have to be glued down. We will replace it if there is an issue with it I like to use just a little bit of weather strip adhesive at the corners but don't go nits with it. I just spent hours cleaning the prior owners mess he made on my orange car. Here is Mark showing how to do it at Okteenerfest last year https://www.dropbox.com/s/qmf2dwvzicwfg6t/9...nstall.mp4?dl=0 (IMG:style_emoticons/default/beerchug.gif) Thanks @Matty900 I will look at it maybe this week.. It will definitely have to be glued in and keep in mind this on my restoration so channels are free and clear of debris. |
Lo-Fi Version | Time is now: 15th May 2024 - 04:14 PM |
