Cabin Electrical connections |
dt4 |
Jun 14 2020, 12:42 PM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
dt4 |
Jun 14 2020, 12:46 PM
dt4 |
Jun 16 2020, 02:38 AM
I have you all baffled then?
or fed up of all the questions (IMG:style_emoticons/default/idea.gif) |
Rob-O |
Jun 16 2020, 04:03 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Can I make a suggestion?
1. Post them one at a time (even if it is within this thread). 2. Give as much information as you can about where the wires are currently and where they seem to come from. 3. Describe your due diligence (ex: I’ve looked at a wiring diagram for my ‘73 2.0L, but I don’t see a yellow with red striped wire anywhere on the wiring diagrams that run through the cabin). With info like that at least people know you’ve done a little searching yourself and still can’t find the answer. But I’ll take a quick stab at a few based on location and what they look like. You can find wiring diagrams online with the color coding. It helps immensely tracking things down. 1. Looks like part of the seat belt cushion pressure sensor/seat belt receiver connectors. Looks like a few have been cut. 2. Looks like connectors for the center console gauges. Doesn’t look like you have a center console though. 3. No idea because I can’t tell where from the picture this is located in the cabin. 4. Looks like part of the seals belt interlock relay wiring. I only say that because of the two large yellow wires in that bundle. What year is the car? |
sixnotfour |
Jun 16 2020, 04:17 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/beerchug.gif) egr counter goes in pass. side foot well..
2. Looks like connectors for the center console gauges. Doesn’t look like you have a center console though. Tucks under carpet your missing the Defrost on light, useses blue black wire Attached thumbnail(s) Attached image(s) |
dt4 |
Jun 16 2020, 06:06 AM
Thank you @Rob-O and @sixnotfour
that helps explain some of the connections I hear the advice about providing more info and what checks I have completed so far, thanks for the pointers. I am just building up the centre console so I will see what I am left with once that is in place |
ClayPerrine |
Jun 16 2020, 06:35 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Photo #1 is supposed to connect to the seat belt buckles for the seat belt interlock system.
Photo #4 is the seatbelt interlock relay. The Yellow and Yellow with a red tracer are already spliced together. So it is bypassed and shouldn't be an issue. Photo #5 is the wiring for the backpad light. |
dt4 |
Jun 16 2020, 08:16 AM
thank you @ClayPerrine
appreciated |
dt4 |
Jun 16 2020, 01:52 PM
porschetub |
Jun 16 2020, 03:01 PM
fiacra |
Jun 16 2020, 03:35 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 326 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
You may find the following thread useful:
http://www.914world.com/bbs2/index.php?act...f=2&t=13582 Many thanks to @sirandy for doing that. I have a 1975 1.8 sitting under a cover in my garage. It is a bit socked in with the debris of a disorganized garage but if you need pictures of specific area I can probably get those for you. I will warn you I cannot always respond quickly, but within 24 hours is reasonable. PM me if you want and I'll send you my email address as that probably is quicker. Good luck!!!!! |
dt4 |
Jun 17 2020, 12:38 AM
You may find the following thread useful: http://www.914world.com/bbs2/index.php?act...f=2&t=13582 Many thanks to @sirandy for doing that. I have a 1975 1.8 sitting under a cover in my garage. It is a bit socked in with the debris of a disorganized garage but if you need pictures of specific area I can probably get those for you. I will warn you I cannot always respond quickly, but within 24 hours is reasonable. PM me if you want and I'll send you my email address as that probably is quicker. Good luck!!!!! thank you, much appreciated @fiacra |
Coondog |
Jun 17 2020, 05:53 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Someone correct me if I am wrong but didn’t all later 914s come pre-wired for a center console ??
Steve |
Jun 17 2020, 07:23 AM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
The one by the shifter is for the center console connections. Temp, voltmeter and clock.
dt4 |
Jun 17 2020, 08:07 AM
Steve |
Jun 17 2020, 08:57 AM
The one by the shifter is for the center console connections. Temp, voltmeter and clock. I just need to identify the wires on the harness to connect with the loom connectors I would purchase a 914 Haynes manual. It has all the diagrams. The first picture goes to a seat pad for the fasten seat belt system. Second picture goes to the center console, The picture with the yellow wire bypass, was for the seat belt interlock system. I also have a 75 914. I am only using some of the wires out of the center console loom. You can also google it and several diagrams will come up. http://volt914.blogspot.com/2007/07/1975-c...ng-diagram.html |
JeffBowlsby |
Jun 17 2020, 11:13 AM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
dt4 |
Jun 17 2020, 01:27 PM
Lo-Fi Version | Time is now: 16th May 2024 - 08:44 PM |
