Things heating up, temps going hot on a cool night, brakes? |
nditiz1 |
Jun 14 2020, 05:24 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Took the silver car out for a cruise after getting the Rennline pedal board installed. It seemed things were OK until I got on the highway to open up. The CHT started to rise at an unsafe level so I pulled over. Dropping from 5th to 4th only helped temporarily. I noticed the clutch grab was very high. I am wondering if the clutch wasn't fully releasing, but I dont think this would cause additional heat only additional slippage? I have since adjusted it. Im more concerned with the brakes as it seemed when I came to a stop the car did not slow to a coasted unassisted stop but more so as though light braking was being applied. None of the wheels felt more hot than the rest. The new pedal assembly I put in was set to the same length as the old but maybe further adjustment is needed. I noticed it was tough to move into the garage one night as though the brakes were applied. That combined with the ebrake not having a crisp click click click leads me to believe something is going on. I did jack the rear up and was able to turn both wheels with little force and noticed some slight dragging, expected right? I need to check the fronts for ease of spin.
Other Ideas? |
Lo-Fi Version | Time is now: 17th May 2024 - 04:05 PM |
