Tie rod removal., While it's on the car. |
911GT2 |
Jun 15 2020, 01:37 PM
Member Group: Members Posts: 195 Joined: 2-March 11 From: The Netherlands Member No.: 12,773 Region Association: Europe |
So today I started replacing the tie rods. Passenger side went fairly difficult but when I broke the tension of the bolt it was somewhat doable. There was enough space there to get some pry bars in there and slowly but steadily half a turn at a time I could get it out.
On the drivers side learning from the passengers side I started with loosening the wheel side of the tie rod and using the tie rod itself to break loose the bolt. But space is tight there and I can't get my pry bars in there the way I could on the passengers side. And instead of loosing up it seems the bolt is tightening. Is there a handy trick I need to know. I don't feel like taking the entire steering rack off. Edit: found this trick: https://youtu.be/-XlIGPl0uSU?t=115 Is that the way to go? |
Tdskip |
Jun 15 2020, 04:32 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
bdstone914 |
Jun 15 2020, 06:16 PM
So today I started replacing the tie rods. Passenger side went fairly difficult but when I broke the tension of the bolt it was somewhat doable. There was enough space there to get some pry bars in there and slowly but steadily half a turn at a time I could get it out. On the drivers side learning from the passengers side I started with loosening the wheel side of the tie rod and using the tie rod itself to break loose the bolt. But space is tight there and I can't get my pry bars in there the way I could on the passengers side. And instead of loosing up it seems the bolt is tightening. Is there a handy trick I need to know. I don't feel like taking the entire steering rack off. Edit: found this trick: https://youtu.be/-XlIGPl0uSU?t=115 Is that the way to go? Kind of a hack video but that is the idea. The disc acts like a jam nut to the inner tie rod end. They do make adjustable or single size hook wrenches that will hook on that disc notch. Attached thumbnail(s) |
911GT2 |
Jun 16 2020, 02:14 AM
To answer my own question and for research purposes.
Yes the method in the video worked like a charm. I think the best method is:
Tdskip |
Jun 16 2020, 06:22 AM
@911GT2 - glad you got it sorted. Please keep us posted with your updates and progress.
914_teener |
Jun 16 2020, 07:59 AM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Can.t remember which side it was but I used a sawzall and a pipe wrench. Peice of cake.
Lo-Fi Version | Time is now: 17th May 2024 - 02:51 AM |
