Need a mechanic in aurora Colorado, Does know of a good mechanic in aurora Colorado? I just moved here |
lwells8433 |
Jun 16 2020, 10:21 AM
Newbie Group: Members Posts: 4 Joined: 13-January 18 From: Los Alamitos Member No.: 21,796 Region Association: Southern California |
Does know of a good mechanic in aurora Colorado? I just moved here and need to find one. Please and Thankyou
kwyjibo |
Jun 19 2020, 01:14 PM
Newbie Group: Members Posts: 4 Joined: 18-February 13 From: Colorado Member No.: 15,549 Region Association: None |
Does know of a good mechanic in aurora Colorado? I just moved here and need to find one. Please and Thankyou Welcome to Colorado Eisenbud's, which is right off the 8th Ave. exit from I25, is good. I've seen the other shops in the area there getting help from John and Jim. I don't know of anyone in Aurora. Depending what you need done, there are other not-so-obvious places around |
lwells8433 |
Jun 26 2020, 11:15 AM
Does know of a good mechanic in aurora Colorado? I just moved here and need to find one. Please and Thankyou Welcome to Colorado Eisenbud's, which is right off the 8th Ave. exit from I25, is good. I've seen the other shops in the area there getting help from John and Jim. I don't know of anyone in Aurora. Depending what you need done, there are other not-so-obvious places around Thankyou I appreciate that, since I moved here after the winter I took the 914 out and front passenger brake is grinding bad and would lock up the tire if I press normal on the pedal. But if I don’t press the pedal there are no noises. The rotor and brakes pad are still in very good shape from when I restored it. So I don’t know if it’s the caliper or something else |
Lo-Fi Version | Time is now: 16th May 2024 - 01:23 PM |
