Just cut out on the Fwy, fuel issue |
johnpierre |
Jun 23 2020, 10:25 AM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
hello 914 community
so I was driving the other Sunday - nice drive with no traffic due to covid, doing 80 on the 405 heading south, for those of you that don't live in LA, that is in LA ;-) and then all of a sudden I just lost power. it sounded like I ran out of gas but that of course is impossible as the tank was 1/2 full. I have a 73, 1.7 fuel injected engine and I have never had this issue. I suppose I can tow the car to a garage but I thought I might put this out there in case this sounds familiar to anyone and I could try to troubleshoot the issue first. is there anything I can check rather easily to solve this? has this happened to anyone else under these conditions? I looked all around the top of the engine as best I could when it happened and I didn't see anything disconcerted or otherwise out of place - but then again I don't really know what I was looking for and it was hot so I really could feel around that much. -jp- |
BeatNavy |
Jun 23 2020, 10:30 AM
When you cycle the key to "on" position do you hear the fuel pump priming (for roughly 1.5 seconds)?
Could be fuel or it could be spark, but that fuel pump test is the easiest (you do it every time you start your car). |
DRPHIL914 |
Jun 23 2020, 10:37 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
When you cycle the key to "on" position do you hear the fuel pump priming (for roughly 1.5 seconds)? Could be fuel or it could be spark, but that fuel pump test is the easiest (you do it every time you start your car). (IMG:style_emoticons/default/agree.gif) ,most likely pump issue, relay or just loose wire on coil , ground etc |
Lo-Fi Version | Time is now: 17th May 2024 - 08:09 PM |
