Just cut out on the Fwy, fuel issue |
johnpierre |
Jun 23 2020, 10:25 AM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
hello 914 community
so I was driving the other Sunday - nice drive with no traffic due to covid, doing 80 on the 405 heading south, for those of you that don't live in LA, that is in LA ;-) and then all of a sudden I just lost power. it sounded like I ran out of gas but that of course is impossible as the tank was 1/2 full. I have a 73, 1.7 fuel injected engine and I have never had this issue. I suppose I can tow the car to a garage but I thought I might put this out there in case this sounds familiar to anyone and I could try to troubleshoot the issue first. is there anything I can check rather easily to solve this? has this happened to anyone else under these conditions? I looked all around the top of the engine as best I could when it happened and I didn't see anything disconcerted or otherwise out of place - but then again I don't really know what I was looking for and it was hot so I really could feel around that much. -jp- |
johnpierre |
Jun 23 2020, 09:40 PM
hey there - thanks for all the help
here is what i found based on your help. #1 im pretty sure the fuel pump is priming - i can here the low whine when i turn the key #2 checked all the fuses and they all look old but non blown, i turned each fuse to see it that would make a better connection #3 it looks like im missing a fuse on either end - not sure i even know it they where there to begin with $3 looked at the coil and it all seemed to be connected, no lose wires #4 i did find a vacuum hose that is not connected, i can't seem to figure out where the hell it connects to however it is coming from a long black straight tube that is at the front of the engine bay #5 checked tank to make sure there was fuel - there is #6 there are only 10 fuses and i could not see any numbers anywhere - must be on the plastic cover that departed me some time ago so i don't know where fuse controls the pump here are some pics to see if you can see something i did not Attached thumbnail(s) |
914_7T3 |
Jun 23 2020, 10:53 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
hey there - thanks for all the help here is what i found based on your help. #1 im pretty sure the fuel pump is priming - i can here the low whine when i turn the key #2 checked all the fuses and they all look old but non blown, i turned each fuse to see it that would make a better connection #3 it looks like im missing a fuse on either end - not sure i even know it they where there to begin with $3 looked at the coil and it all seemed to be connected, no lose wires #4 i did find a vacuum hose that is not connected, i can't seem to figure out where the hell it connects to however it is coming from a long black straight tube that is at the front of the engine bay #5 checked tank to make sure there was fuel - there is #6 there are only 10 fuses and i could not see any numbers anywhere - must be on the plastic cover that departed me some time ago so i don't know where fuse controls the pump here are some pics to see if you can see something i did not Here are the fuse locations for a '73 from the owners manual. Looks like you are missing the left high beams (white 8 amp) and headlight motors (blue 25 amp) As for fuel pump relay, you can reference this relay board diagram showing the underside to help identify the loacation. |
Lo-Fi Version | Time is now: 21st May 2024 - 06:00 PM |
