What is this part? |
FJ1200 |
Jun 24 2020, 01:48 PM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings,
I took the two column switches out to clean and lubricate them. When separating them, this little tab hit the floor and for the life of me I can not figure out which screw it fits under and what it's purpose is. This is a 72 914. Thanks, Dan Attached image(s) |
76-914 |
Jun 24 2020, 04:43 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
1/2 of a fuse holder (IMG:style_emoticons/default/beerchug.gif)
FJ1200 |
Jun 24 2020, 05:09 PM
I don't think its part of a fuse holder. The hole is a perfect fit for the cheese head screws that hold the switches in place, and it dropped when I pulled the screws out of the 2 column switches.
Thanks anyway, anyone else? |
bbrock |
Jun 24 2020, 05:14 PM
Isn't that the little copper contact in the wiper switch that is loose so everybody loses it right before they find out their horn no worky?
scallyk9 |
Member Group: Members Posts: 321 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
Those always fall out and hit the floor, then I spend time figuring where it fell from. Over and over again...I don't learn quickly. You are correct. It goes where it steps down a level and yes, the hole s for one of the long mounting screws. It becomes more obvious when you go to assemble the wiper and light switch "sandwich".
FJ1200 |
Jun 24 2020, 05:23 PM
So it sounds like it goes between the two switches, does the tab point inward and engage something?
Thanks, Dan |
Bleyseng |
Jun 25 2020, 07:09 AM
Its the special brass contact piece that is the grounding connection to make the intermittent or flick wipe work. Everyone loses them and took me a year to find one to make my setup work.
FJ1200 |
Jun 25 2020, 03:33 PM
Well, I needed to call AA to order a few pieces so I ran this past George. It fits into the upper right screw position and completes the ground circuit for the wipers in the wash function. Picture attached. As always thanks to the help and knowledge of George at AA.
Lo-Fi Version | Time is now: 15th May 2024 - 01:39 PM |
