Front suspension, refresh suspension |
framos914 |
Jun 26 2020, 12:45 AM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
looking for a little advice.
Just removed my front suspension because everything is at least 38 years old. I believe it's mostly from a 76 911 including the sway bar. Also S calipers, 5 lug and struts. I want to get a good look at the rack and install Turbo Tie Rods and already have new Koni strut inserts installed. Not sure if I want to tackle the bushings and ball joints myself since I don't have the right tools and equipment. Any suggestions? Is it a good Idea to keep this set up and refresh it? Any recommended places for the work? Corona, Anaheim CA area. Thanks |
mlindner |
Jun 27 2020, 12:35 PM
Senior Member Group: Members Posts: 1,521 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
framos914, take it all apart, clean, paint and replace bushing. Lots of fun.....
The rubber bushing come out easy with a torch and the ball joint you only need the large type socket (I have one I can send you to use). Best, Mark |
Lo-Fi Version | Time is now: 18th May 2024 - 01:08 AM |
