Transmission, Won’t go into any other gears |
ohionegretes |
Jun 26 2020, 08:34 PM
Newbie Group: Members Posts: 3 Joined: 9-December 19 From: Ohio Member No.: 23,717 Region Association: North East States |
Have a 1973 Porsche 914. I’ve had it for about six months now, it will not go into anything but second or third gear. Not sure if I need a bunch of new bushings or linkage for the shifter.
fiacra |
Jun 26 2020, 09:32 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 331 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Have a 1973 Porsche 914. I’ve had it for about six months now, it will not go into anything but second or third gear. Not sure if I need a bunch of new bushings or linkage for the shifter. What have you checked so far? Best to let everybody know that you have at least started to make an effort, and what you have found. That will help guide the advice/guidance you get. Bushings are a good place to start. Tons of information on previous threads from other people with similar problems. Best way that I, and many others, have found to search this forum is to use Google and add the search term "914World." |
porschetub |
Jun 27 2020, 12:38 AM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have a 1973 Porsche 914. I’ve had it for about six months now, it will not go into anything but second or third gear. Not sure if I need a bunch of new bushings or linkage for the shifter. What have you checked so far? Best to let everybody know that you have at least started to make an effort, and what you have found. That will help guide the advice/guidance you get. Bushings are a good place to start. Tons of information on previous threads from other people with similar problems. Best way that I, and many others, have found to search this forum is to use Google and add the search term "914World." (IMG:style_emoticons/default/agree.gif) appears little done (IMG:style_emoticons/default/slap.gif) . |
TheCabinetmaker |
Jun 27 2020, 08:38 AM
First thing l would do is crawl under the car and give the shift rod a few good shakes. It should be solid and tight. Then, pull the rod covers,. And visually inspect the bushings. Good luck
rhodyguy |
Jun 27 2020, 09:10 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Something is awry with the linkage assembly or the transmission. Perhaps both.
Tdskip |
Jun 27 2020, 09:20 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Look at the first picture here - will give you a better idea about #1 most likely issue.
http://www.914world.com/bbs2/index.php?showtopic=342826 |
Lo-Fi Version | Time is now: 21st May 2024 - 01:01 PM |
