BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
Found one. Thanks! |
JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,208 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,005 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I have the mounting plate for you. Will PM. Looks like the above poster has the grommets. Screws are easy to come by.
BillC |
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? |
JOEPROPER |
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? I can send these to you. The screws are sheet metal screws that you can get from AA or locally. These grommets are free. You can thank @914Sixer PM me for details. |
BillC |
I need a mounting plate for a manifold pressure sensor (MPS) with grommets, screws and spacers. I discovered this afternoon that they mangled the mount and lost the correct grommets and screws. Thanks! @BillC is this what you need? ![]() @JOEPROPER Yes, I need those. Any chance you also have the screws that go with them? I can send these to you. The screws are sheet metal screws that you can get from AA or locally. These grommets are free. You can thank @914Sixer PM me for details. @ JOEPROPER PM sent. Thank you very much! |
G e o r g e |
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,984 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,220 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
The ones I was selling OEM later Bosch without the bass center. MIGHT have some used ones. Have to look.
FlacaProductions |
Very good - see you see. Thank you!
Lo-Fi Version | Time is now: 16th August 2025 - 04:55 AM |
