Re-Conversion of a '70 914, Patching that Big V8 radiator cutout pt. 1 |
76-914 |
Jun 28 2020, 08:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The engine is sold. I'll soon have a very fresh 901 w/ an "H" gear for sale as well as some other goodies soon for those planning an SBC conversion. I couldn't do much with this sitting in my garage as it already is stuffed to the max. Therefor I felt it somewhat necessary to sell this before commencing with the re-conversion. I've been silently (yeh, I know; me silent) working in the background for a few months fabricating some items that will be needed. I'll do my best to document things a bit more accurately than the previous conversion. Once again I'll be using the Subaru 6 and Subaru transmission. I've had tremendous success with this platform so I might as well repeat myself. So sit back, bear with me and watch as I stumble along and occasionally embarrass myself. Mistakes are an integral part of my journey. (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) |
76-914 |
Aug 27 2020, 03:14 PM
Thx, They're like women."They all look good when you ain't feeding 'em"! (IMG:style_emoticons/default/shades.gif) Now back to our irregular non-scheduled program.
While Lady Drivetrain sits patiently in the corner awaiting her shiny cradle: I wanted to get a better shot of the slave cylinder line that is straightened and moved to the psg side. And this is the removed part that I referred to earlier as a Whatchamacallit. Ans speaking to the transmission: If you plan to use a neutral safety switch, this is the one you'll need. Remove the old one which is N/O in neutral and replace it with this one which is N/C in neutral. Install it in series with the ground on the starter relay. I'll get into that later. Also, I wanted some real numbers on how much gear oil is needed after converting the TY75 to front wheel drive. I'd heard 1 xtra qt but I'm going to find out. I took a 1 gal can, opened it up and sat the center differential some bearings and washers (which you can't see) on the bottom and this one short shaft with it's bearing then filled the can with used motor oil to a mark on the inside of the can. It is roughly the height of the center differential. Then let it sit a few minutes so the bearings and other crevices could fill with oil.Next I removed the parts and let them begin to drip the oil back into the container. Tomorrow AM I will measure how much additional oil it takes to fill it to that line. Then add the one shaft (pictured below) I couldn't fit with the other parts and add oil to another mark which I'll add above the old one. Once I've determined the additional volume that was required I'll measure the amount the nose cone held and subtract that amount. I'll probably discover that it is 1 qt. indeed and that I've managed to piss off a hour ,once again. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:02 AM |
