Re-Conversion of a '70 914, Patching that Big V8 radiator cutout pt. 1 |
76-914 |
Jun 28 2020, 08:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,492 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The engine is sold. I'll soon have a very fresh 901 w/ an "H" gear for sale as well as some other goodies soon for those planning an SBC conversion. I couldn't do much with this sitting in my garage as it already is stuffed to the max. Therefor I felt it somewhat necessary to sell this before commencing with the re-conversion. I've been silently (yeh, I know; me silent) working in the background for a few months fabricating some items that will be needed. I'll do my best to document things a bit more accurately than the previous conversion. Once again I'll be using the Subaru 6 and Subaru transmission. I've had tremendous success with this platform so I might as well repeat myself. So sit back, bear with me and watch as I stumble along and occasionally embarrass myself. Mistakes are an integral part of my journey. (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) |
76-914 |
Sep 22 2020, 01:48 PM
Picking up where I left off. Here is a pic of the pedal cluster before it's re-installed. I did not use the AN3 90 pictured as it was too tight against the bulkhead. I did not run into this on the 73 conversion so I was surprised when it didn't fit as planned. This car had some metal work done to it previously and I suspect something changed slightly during that process.
Here are several pics from the underside of it mounted in place. You can see the black AN3 swivel 90 that I used in place of the one in the other pic's. It was tighter than Socks on a Rooster but fit nicely. A view from inside as it sits before connecting the fork, clevis or throttle cable. Connecting the pedal to the slave cylinder push rod. You can see the AN3 line in a couple of the pics. It is fed through the old clutch tube. And a few with the throttle cable connected showing the clearance. It's close but they do clear one another. |
Lo-Fi Version | Time is now: 27th April 2024 - 02:46 PM |
