Re-Conversion of a '70 914, Patching that Big V8 radiator cutout pt. 1 |
76-914 |
Jun 28 2020, 08:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,490 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The engine is sold. I'll soon have a very fresh 901 w/ an "H" gear for sale as well as some other goodies soon for those planning an SBC conversion. I couldn't do much with this sitting in my garage as it already is stuffed to the max. Therefor I felt it somewhat necessary to sell this before commencing with the re-conversion. I've been silently (yeh, I know; me silent) working in the background for a few months fabricating some items that will be needed. I'll do my best to document things a bit more accurately than the previous conversion. Once again I'll be using the Subaru 6 and Subaru transmission. I've had tremendous success with this platform so I might as well repeat myself. So sit back, bear with me and watch as I stumble along and occasionally embarrass myself. Mistakes are an integral part of my journey. (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) |
76-914 |
Oct 5 2020, 06:30 PM
The fuel hose arrived this weekend so I was able to button that up and run the line up for the MC reservoir. That allowed me to install the gas tank. This is the tank that I originally had modified for the conversion on the '73. You might remember that I pulled it installed another with an external pump. That was done when I was chasing my tail and trying to eliminate the vapor lock problem was I was having at that time. Turned out that it had nothing to do with the Subaru submerged pump. (IMG:style_emoticons/default/headbang.gif) Regardless I kept it and I'm glad that I did. One less thing to do. Beside, I really like having the hose connections on top.
I was able to scratch the throttle cable off the list today. The cable from the V8 was still installed so I thought "What the Hell" nothing to lose. I'll try and modify it for my needs. There isn't much to it. As you can see in the first pic below it was way too long and didn't have the correct end on it either. I needed to shorten the sheath by 12" as well as the 3/16 inner steel cable. I attached a 5/16 FI style clamp adjacent to the cut. The innermost part of the sheathing has a 3/32" plastic tube. Around that is a SS flat wound wire and finally the black plastic outer layer. I used a Dremel blade to cut the cable. I cut it from the end that mates to the firewall since these are usually falling apart at this junction. Just my luck this on wasn't. (IMG:style_emoticons/default/evilgrin.gif) I was able to remove the 12" section by placing the small end in the vise and clamping down slightly on the edges of each clamp mark.i.e. the clamp they used in the factory is octagon shaped. By pressing slightly on the crown of each corner helps to round out the end al little bit. Then pulling the cable while rotating it clockwise. it slowly backed out. To get the sleeved end back to round I placed a 17/64" drill bit with the bald end up in the vise. Then hammered the sleeve back over it. It only went in about 14". I looked inside the sleeve and noticed these tiny dimples that are there to help grip the sleeve. So I used a 1/4" bit to flatten the dimples some what then followed up with the 17/64" to round it out. Now I was able to thread the cable sheath back onto the sleeve by pushing while turning counter clockwise. It worked like a champ. I won't trim the steel cable until I have the pedal board and gas peddle back in place but that will only take a minute. I'm happy with the way it turned out but in all honesty the only reason I tried this was I had nothing to lose and everything to gain. Start to finish was less than 30 minutes. Sorry about the order of the pics. Something about this site isn't friendly about posting and editing pics with this Mac. Hoping for some upgrades here now that we are supporting it $$$ wise. Attached image(s) |
Lo-Fi Version | Time is now: 26th April 2024 - 05:22 AM |
