Re-Conversion of a '70 914, Patching that Big V8 radiator cutout pt. 1 |
76-914 |
Jun 28 2020, 08:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,491 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The engine is sold. I'll soon have a very fresh 901 w/ an "H" gear for sale as well as some other goodies soon for those planning an SBC conversion. I couldn't do much with this sitting in my garage as it already is stuffed to the max. Therefor I felt it somewhat necessary to sell this before commencing with the re-conversion. I've been silently (yeh, I know; me silent) working in the background for a few months fabricating some items that will be needed. I'll do my best to document things a bit more accurately than the previous conversion. Once again I'll be using the Subaru 6 and Subaru transmission. I've had tremendous success with this platform so I might as well repeat myself. So sit back, bear with me and watch as I stumble along and occasionally embarrass myself. Mistakes are an integral part of my journey. (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) |
76-914 |
Nov 9 2020, 06:04 PM
It's been a few weeks and only a few items remain. One of those items are the shifter cables which should arrive by the end of this week. I haven't even thought about how I will cover the shifter in this car. The other one was easy as I could hide everything between the console and middle cushion. But moving ahead I use some wire rope to visualize the route the cables will run because it is somewhat similar to the cables stiffness and will prevent me from making too small of a radius. I clamp the cables to the shifter on one end and to the transmission on the other. Nothing magic here but it does help to see where they will run.
They will lay on top of the tunnel then drop thru the rear tunnel access cover and out the same hole in the firewall that the old shift rod passed through. And from the engine compartment side. And finally to the transmission. I cut the cover to allow the cables to enter the tunnel. Then make a couple of small templates for the gussets. And form the gussets |
Lo-Fi Version | Time is now: 26th April 2024 - 06:47 PM |
