front trunk pull handle bracket? |
dt4 |
Jun 29 2020, 01:15 PM
Senior Member Group: Members Posts: 502 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
Is there a bracket that holds the pull handle in position?
mine is quite loose, it works fine but sort of "floats" above the fuse box rather than being fixed to anything solid |
dr914@autoatlanta.com |
Jun 29 2020, 02:18 PM
914 Guru Group: Members Posts: 7,833 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
dt4 |
Jun 30 2020, 12:29 AM
yes and it is secured by two allen bolts, usually comes with the pull handle Is there a bracket that holds the pull handle in position? mine is quite loose, it works fine but sort of "floats" above the fuse box rather than being fixed to anything solid thanks George Ill have to rummage through the box of bits and see if there is anything that looks appropriate lurking in a corner |
Lo-Fi Version | Time is now: 6th May 2024 - 12:31 AM |
