Double relay question on 74 1.8 liter, Doublerelay |
Mcraneiowa |
Jul 2 2020, 01:44 PM
Member Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None |
I’m excited to be back to the point of hooking up the wiring to the car after reinstalling the engine last night. Everything seems pretty straightforward up to this point except with the double relay. My 914 is a 74 1.8 L engine with fuel injection. My question is which side of the relay do I use? If it’s pointing down and I’m plugging in from the bottom do I hook too the left side or the right side? Currently I have it plugged into the left side but no power or anything hooked up to the car so I’m not worried about frying anything at this point I just don’t want to fry anything. Another question, why do we have a double relay if we only use one side? I appreciate the help thanks, Mike
ClayPerrine |
Jul 2 2020, 06:41 PM
Life's been good to me so far..... Group: Admin Posts: 15,485 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The double relay will have one connection that comes from the engine harness. It will have a mix of colored wires on it. The other side will come from the fuel injection harness, and it will have all white wires.
If you don't have both the car will not run. There will be a big red wire on the harness side that attaches to the battery. The engine harness will have an extra yellow wire with a spade connector hanging out alone at the 12 pin connector. If you don't have that, you have the wrong engine harness. Take pictures and we can help better. Clay |
Mcraneiowa |
Jul 3 2020, 06:49 AM
The double relay will have one connection that comes from the engine harness. It will have a mix of colored wires on it. The other side will come from the fuel injection harness, and it will have all white wires. If you don't have both the car will not run. There will be a big red wire on the harness side that attaches to the battery. The engine harness will have an extra yellow wire with a spade connector hanging out alone at the 12 pin connector. If you don't have that, you have the wrong engine harness. Take pictures and we can help better. Clay Clay, thank you for the information. I was working late last night and just overlooked the other series of wires were kind of stuck down in among the spark plug wires. So I have both plugged in and hope to fire her up after several years of sitting. I really appreciate your help. The site is fantastic for helping some of us become familiar with our cars |
Lo-Fi Version | Time is now: 27th May 2024 - 02:45 AM |
