QUOTE(Mcraneiowa @ Jul 3 2020, 07:49 AM)
QUOTE(ClayPerrine @ Jul 2 2020, 07:41 PM)
The double relay will have one connection that comes from the engine harness. It will have a mix of colored wires on it. The other side will come from the fuel injection harness, and it will have all white wires.
If you don't have both the car will not run. There will be a big red wire on the harness side that attaches to the battery. The engine harness will have an extra yellow wire with a spade connector hanging out alone at the 12 pin connector.
If you don't have that, you have the wrong engine harness.
Take pictures and we can help better.
Clay
Perfect. This the point I am at. Will start this process tomorrow. Appreciate your knowledge more than you know.
Clay, thank you for the information. I was working late last night and just overlooked the other series of wires were kind of stuck down in among the spark plug wires. So I have both plugged in and hope to fire her up after several years of sitting. I really appreciate your help. The site is fantastic for helping some of us become familiar with our cars
Now that both plugs are connected, run some basic tests.
1. Disconnect the yellow wire from the starter and turn the key. You should hear the fuel pump running.
2. Manually open the air flow meter flap. You should hear the fuel pump running.
3. Get a noid light, plug it into each injector connector and crank the car. The light should flash.
If all that works, you should be able to star the engine.
