CV Bolt Replacement, Best Practice and While I'm in There? |
Nogoodwithusernames |
Jul 2 2020, 10:07 PM
Member Group: Members Posts: 237 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Was going to take the 914 out for a spin tonight (IMG:style_emoticons/default/driving.gif) and two streets from the house *POP* and engine free revs... Figured I broke an axle or something along those lines and sure enough drive side axle is no longer connected to the trans. Haven't dug in to find out if the bolts sheared or backed out but it needs fixing.
I'm planning on replacing all the CV bolts with the safety wire versions from 914 rubber and obviously safety wiring them. But should I locktite them? Antisieze? Neither? Figure I'd clean them and repack the grease, anything else while I'm under there? Might finally put the new shifter bushings I've had sitting around for eons... (Also how many are there? I think VW has 6 bolts per CV, same for our little NARP? *EDIT* 914 rubber says it right on their site, 16 total.) |
iankarr |
Jul 3 2020, 07:37 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Like many things on our cars, it all works as a system. New bolts and schnoor washers should be fine. No loctite or anything else needed. I’ve never had any back out. The safety wire is great for extra peace of mind. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:59 PM |
