CV Bolt Replacement, Best Practice and While I'm in There? |
Nogoodwithusernames |
Jul 2 2020, 10:07 PM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Was going to take the 914 out for a spin tonight (IMG:style_emoticons/default/driving.gif) and two streets from the house *POP* and engine free revs... Figured I broke an axle or something along those lines and sure enough drive side axle is no longer connected to the trans. Haven't dug in to find out if the bolts sheared or backed out but it needs fixing.
I'm planning on replacing all the CV bolts with the safety wire versions from 914 rubber and obviously safety wiring them. But should I locktite them? Antisieze? Neither? Figure I'd clean them and repack the grease, anything else while I'm under there? Might finally put the new shifter bushings I've had sitting around for eons... (Also how many are there? I think VW has 6 bolts per CV, same for our little NARP? *EDIT* 914 rubber says it right on their site, 16 total.) |
bdstone914 |
Jul 3 2020, 07:50 AM
bdstone914 Group: Members Posts: 4,526 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Clean the holes for the CV bolts. Grease affects the torque value.
If you dont use safety wire put a dot of bright paint on the bottom of the bolt and flange. Check occasionally to see if the dots do not align and they are beginning to back out. |
Lo-Fi Version | Time is now: 25th May 2024 - 04:35 PM |
