Big backfire, 2.7L CIS from 1976 911 |
Kansas 914 |
Jul 4 2020, 10:08 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I tried to start the car as I normally do but back fired (pretty loud) I tried to re-start (it did this once before a few years ago) but this time it didn't restart.
I pulled the air cleaner cover and saw a hole in the filter and the pop-off valve was in pieces. I haven't taken the air box off yet but that is next if I can't get the old pop-off valve out. It looks like the engine builder sealed the air box (and the pop-off valve) with some kind of "goop". Fun times... |
rgalla9146 |
Jul 7 2020, 03:44 PM
Advanced Member Group: Members Posts: 4,555 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The hinge should be at the rear of the plenum closest to the cooling fan to allow full action.
Prepare all mating surfaces with acetone. Be certain surfaces are free of oil or contamination Mix JB weld according to instruction and apply only to outer rim of valve tube. This prevents glue from entering intake. Press valve square into plenum being certain it is fully seated. Allow glue to fully harden before starting. |
Lo-Fi Version | Time is now: 19th May 2024 - 11:41 AM |
