Jack receiver or donut mounting point repair first? |
Tdskip |
Jul 5 2020, 01:35 PM
So I made the “mistake” of looking more carefully at my problem child blue 914 today. When the DPO tried to repair the hell how damage they put a flat piece of metal where the passenger side rear donut goes.
They also used an incorrect piece of metal where the jacking point goes. I have good long/jack receiver donor metal as pictured. So - am I better off replacing the donut area or the jack receive point of the long? Thanks! |
BPic |
Jul 5 2020, 01:51 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
Thinking on how they fit on the car I don’t think it matters. The donut and triangle fit on the inside of the long seam and the part you have is outside. If you’re using the entire piece and not just a jack point I would probably do that part first just because I like to do the bigger things first.
Tdskip |
Jul 5 2020, 01:54 PM
Thinking on how they fit on the car I don’t think it matters. The donut and triangle fit on the inside of the long seam and the part you have is outside. If you’re using the entire piece and not just a jack point I would probably do that part first just because I like to do the bigger things first. Thank you for the reply and hope you had a good Fourth of July. I was leaning towards that section as well because it should make it easier to fit it properly because it has all the factory points on it still making it easier to lineup. Thanks again for the response. |
euro911 |
Jul 5 2020, 02:08 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,846 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
A good mod that I do ... enlarge the existing weep hole to allow better drainage and add a second weep hole at the opposite end ...
Tdskip |
Jul 5 2020, 02:30 PM
Great tip Mark, thanks
bkrantz |
Jul 5 2020, 08:53 PM
914 Guru Group: Members Posts: 7,737 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I did the same mod. Makes it possible to actually flush out dirt.
Tdskip |
Jul 5 2020, 09:09 PM
Thanks for the confirmation.
Ordered the metal repair piece, interestingly these are apparently not support to be used for jacking points according to an earlier thread here. |
euro911 |
Jul 6 2020, 01:17 AM
Thanks for the confirmation. Ordered the metal repair piece, interestingly these are apparently not support to be used for jacking points according to an earlier thread here. Every VW I've owned (including the 914) uses a similar jacking method ... that's where the stock VW jack fits (IMG:style_emoticons/default/popcorn[1].gif) |
Tdskip |
Jul 6 2020, 10:10 AM
Thanks for the confirmation. Ordered the metal repair piece, interestingly these are apparently not support to be used for jacking points according to an earlier thread here. Every VW I've owned (including the 914) uses a similar jacking method ... that's where the stock VW jack fits (IMG:style_emoticons/default/popcorn[1].gif) Hi Mark. I'm referencing this thread; http://www.914world.com/bbs2/index.php?showtopic=344274 |
Lo-Fi Version | Time is now: 29th April 2024 - 05:57 AM |
