Fuel pump relocation 2 questions... |
Wyvern |
Jul 5 2020, 05:18 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
I am going to relive and change to a 2 port.
Found lost of good info here. 1. I can’t seem to find a late blister. Why couldn’t I just use a flat plate? 2. Am I correct in thinking other than cutting a door hatch and using the blister )or my home made door) that the fuel hose on this set up would be shorter and more protected than hanging the pump near the steering rack? The hose going out of the tank area then need to go back through just seems less desirable. |
Montreal914 |
Jul 5 2020, 07:12 PM
Senior Member Group: Members Posts: 1,554 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Got mine from Bruce Stone @bdstone914 a few years back. You might want to contact him. Good luck with your search.
As for the flat panel idea, it would probably depend what kind of mounting you will use and if your car has a front sway bar. This is a picture from 914world and it also nicely shows the square filter and it's bracket. I think this filter with the tabs is difficult to find. I was considering removing the filter bracket in the back of the car and welding it in the stock 75 location. |
Wyvern |
Jul 5 2020, 07:18 PM
Got mine from Bruce Stone @bdstone914 a few years back. You might want to contact him. Good luck with your search. As for the flat panel idea, it would probably depend what kind of mounting you will use and if your car has a front sway bar. This is a picture from 914world and it also nicely shows the square filter and it's bracket. I think this filter with the tabs is difficult to find. I was considering removing the filter bracket in the back of the car and welding it in the stock 75 location. Thanks for that photo . the cover needs the blister because room is minimal ans I have a sway bar ... |
Jonathan Livesay |
Jul 5 2020, 08:17 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Got mine from Bruce Stone @bdstone914 a few years back. You might want to contact him. Good luck with your search. As for the flat panel idea, it would probably depend what kind of mounting you will use and if your car has a front sway bar. This is a picture from 914world and it also nicely shows the square filter and it's bracket. I think this filter with the tabs is difficult to find. I was considering removing the filter bracket in the back of the car and welding it in the stock 75 location. Thanks for that photo . the cover needs the blister because room is minimal ans I have a sway bar ... Maybe someone would want to make and sell this (relatively) simple piece of sheetmetal? |
Lo-Fi Version | Time is now: 13th May 2024 - 05:15 AM |
