Fuel pump relocation 2 questions... |
Wyvern |
Jul 5 2020, 05:18 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
I am going to relive and change to a 2 port.
Found lost of good info here. 1. I can’t seem to find a late blister. Why couldn’t I just use a flat plate? 2. Am I correct in thinking other than cutting a door hatch and using the blister )or my home made door) that the fuel hose on this set up would be shorter and more protected than hanging the pump near the steering rack? The hose going out of the tank area then need to go back through just seems less desirable. |
mlindner |
Jul 6 2020, 05:14 AM
Senior Member Group: Members Posts: 1,520 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
ClayPerrine |
Jul 6 2020, 10:42 AM
Life's been good to me so far..... Group: Admin Posts: 15,455 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Copper line is not good in a fuel system. Copper will work harden with vibration, and eventually crack and leak. Plus, some gasoline mixes will erode the inside of the copper tube and put crap into the fuel. |
mlindner |
Jul 6 2020, 10:55 AM
Copper line is not good in a fuel system. Copper will work harden with vibration, and eventually crack and leak. Plus, some gasoline mixes will erode the inside of the copper tube and put crap into the fuel. Thanks Clay, its not copper just has that look. This car will be used for mostly track events, so leaks or smell up front not a problem. |
Lo-Fi Version | Time is now: 13th May 2024 - 08:09 AM |
