Fuel pump relocation 2 questions... |
Wyvern |
Jul 5 2020, 05:18 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
I am going to relive and change to a 2 port.
Found lost of good info here. 1. I can’t seem to find a late blister. Why couldn’t I just use a flat plate? 2. Am I correct in thinking other than cutting a door hatch and using the blister )or my home made door) that the fuel hose on this set up would be shorter and more protected than hanging the pump near the steering rack? The hose going out of the tank area then need to go back through just seems less desirable. |
914_teener |
Jul 20 2020, 08:15 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
My advice is to mount it below and above the air diverter on the passenger fire wall. Much easier installation and easier to access. There are several threads on this going several if not more years ago.
I know Porsche changed the location to the front under the steering raxk on the late cars but I wouldn.t.locate the pump there unless you are going to replace the fuel lines in the tunnel. There are a lot more reasons in my mind to not to move it to the front but if you are planning on moving it there....plan on replacing the lines as well for one really good reason. (IMG:style_emoticons/default/blowup.gif) (IMG:style_emoticons/default/blowup.gif) Edit: See someone commented on that already....oh yea....don.t use copper...fuel corosion is only one reason not to use it. Good luck. |
Wyvern |
Jul 20 2020, 09:55 PM
My advice is to mount it below and above the air diverter on the passenger fire wall. Much easier installation and easier to access. There are several threads on this going several if not more years ago. I know Porsche changed the location to the front under the steering raxk on the late cars but I wouldn.t.locate the pump there unless you are going to replace the fuel lines in the tunnel. There are a lot more reasons in my mind to not to move it to the front but if you are planning on moving it there....plan on replacing the lines as well for one really good reason. (IMG:style_emoticons/default/blowup.gif) (IMG:style_emoticons/default/blowup.gif) Edit: See someone commented on that already....oh yea....don.t use copper...fuel corosion is only one reason not to use it. Good luck. Thank you . tunnel lines done . |
Lo-Fi Version | Time is now: 12th May 2024 - 01:43 PM |
