Fuel pump relocation 2 questions... |
Wyvern |
Jul 5 2020, 05:18 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
I am going to relive and change to a 2 port.
Found lost of good info here. 1. I can’t seem to find a late blister. Why couldn’t I just use a flat plate? 2. Am I correct in thinking other than cutting a door hatch and using the blister )or my home made door) that the fuel hose on this set up would be shorter and more protected than hanging the pump near the steering rack? The hose going out of the tank area then need to go back through just seems less desirable. |
mlindner |
Jul 6 2020, 05:14 AM
Senior Member Group: Members Posts: 1,519 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
ClayPerrine |
Jul 6 2020, 10:42 AM
Life's been good to me so far..... Group: Admin Posts: 15,454 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Copper line is not good in a fuel system. Copper will work harden with vibration, and eventually crack and leak. Plus, some gasoline mixes will erode the inside of the copper tube and put crap into the fuel. |
porschetub |
Jul 20 2020, 10:20 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Copper line is not good in a fuel system. Copper will work harden with vibration, and eventually crack and leak. Plus, some gasoline mixes will erode the inside of the copper tube and put crap into the fuel. Copper has no use in our cars but I think the pic is showing plated large diameter brake line which is plated that colour…..just saying or maybe copper (IMG:style_emoticons/default/confused24.gif) . |
Lo-Fi Version | Time is now: 12th May 2024 - 05:15 PM |
