914-6 Flywheel O-ring Size, Flywheel O-Ring, o Ring |
Movin6 |
Jul 6 2020, 09:36 AM
Member Group: Members Posts: 76 Joined: 27-July 09 From: New England Member No.: 10,615 Region Association: North East States |
I am finally reassembling my 914-6 after the Dr Evil transaxle rebuild clinic. I do not recall seeing an O-ring between the flywheel and crankshaft when I dissembled.
What size is the O-ring? It appears to go in the inner grove as shown in the pic. Appears to be 27mm OD, 22mm ID, 2.5mm cross section. Or should I say my kit has one about that size that fits. Does anyone have the exact size? |
Movin6 |
Jul 6 2020, 09:38 AM
roblav1 |
Jul 6 2020, 09:46 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Do you mean a dowel pin? If I recall correctly, no dowel pin. Only 6 brand new flywheel bolts.
sixnotfour |
Jul 6 2020, 09:50 AM
914 Wizard Group: Members Posts: 10,416 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Pilot Bearing
Retroracer |
Jul 6 2020, 10:25 AM
Senior Member Group: Members Posts: 609 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Pilot bearing receptacle on flywheel. Pelican has them, - Tony |
roblav1 |
Jul 6 2020, 10:37 AM
Ha ha! I thought his finger was pointing at a flywheel bolt hole!
Movin6 |
Jul 6 2020, 11:45 AM
Pilot Bearing Thanks! I found my bushing and new pilot bearing. (This is what happens with long delays between take apart and put together, LOL.) Not obvious where the O-ring would go? I assume between the flywheel and crankshaft? The outer grove is barely a grove, and is way more than the 58mm mentioned for OD. I believe this is the original -6 flywheel. (Yes has been machined / resurfaced.) |
roblav1 |
Jul 6 2020, 12:50 PM
There's no o-ring in there at all. Do you mean the rear crankshft seal?
Movin6 |
Jul 6 2020, 01:09 PM
rgalla9146 |
Jul 6 2020, 04:00 PM
Movin6 |
Jul 8 2020, 11:00 PM
Thanks for all the replies. So no O-Ring on a 914-6. (Only on a -4.)
Is there a felt washer? If so, I assume it goes between the pilot bearing and the 6-hole washer / plate, correct? Thanks! |
porschetub |
Jul 8 2020, 11:34 PM
Thanks for all the replies. So no O-Ring on a 914-6. (Only on a -4.) Is there a felt washer? If so, I assume it goes between the pilot bearing and the 6-hole washer / plate, correct? Thanks! Not that I know of but my flywheel isn't a 914/6 one but 911 2.2T,no "o" ring in mine. The felt washer is built into the pilot bearing. What concerns me is the machined surface that mates to the flywheel appears to have been sandblasted ?? is that just me or just the photo?. Cheers. |
Movin6 |
Jul 9 2020, 12:17 PM
Looks like the felt washer is #6 in the "bush complete" listed as 901 102 025 01
Will check what's in mine when I remove the old bearing from the bushing, likely guess at size to replace it. |
Movin6 |
Jul 9 2020, 02:01 PM
Lo-Fi Version | Time is now: 1st May 2024 - 10:27 PM |
