Transmission Shifer adjustment, Adjusting shifter after replacing bushings |
sjhenry1075 |
Jul 6 2020, 12:26 PM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
I replaced the old transmission bushings last week. Before I had, there was so much play that I could move the gear shift all over the place when it was still in gear, and I could not shift into 4th gear without issues. After receiving feedback from the forum, it was clear that I had to change the bushings.
Once I started I found that the old bushings were cracked, broken or missing all together. After I finished replacing the bushings, I found that the shifting is all out of whack. First, I could not shift into 1st or reverse. I fixed this by twisting the rod that goes out the firewall. Now, it still will not go into fourth gear and it grinds when I downshift into 3rd or 2nd. I'm assuming that it's nicking 1st gear / reverse during downshifting? My question is, is this still a matter of twisting the rod? Did I go too far? Or, this this a forward/backward issue. I already posted this on the FageBook page, I just wanted to get some feedback here as well. |
ndfrigi |
Jul 6 2020, 02:40 PM
Hope this will help, if your forward and backward position on ur shifter looks on the right position (mark the rod using a marker to keep the rod measurement that goes in the bottom shifter), adjustment to get 4th and 5th should be just the rod by turning it clockwise (from the bottom of the shifter).
or from scratch, remove your rod from the bottom of shifter then place your transmission to 2nd gear (by hand on the tranny side) then use the rear access of your tunnel (right side of driver to the center tunnel before firewall) and hold the shift rod to keep the tranny on 2nd gear then install back your shifter rod to your shifter that is position to 2nd gear of your shifter. that should be it or maybe just a very little adjustment on the bottom shifter bottom rod. |
rhodyguy |
Jul 6 2020, 07:28 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Use the dentent plate as a guide for the 2/3 plane. Side shift? Place in second gear at trans and lock the rear rod in place with a pair of vicegrips where the rod goes thru the engine support bar. The only connection you might have to fight a bit is where the front rod enters the coupler for the shifter.
sjhenry1075 |
Jul 7 2020, 12:09 PM
Thank you both for advice. What is a dentent plate?
Lo-Fi Version | Time is now: 8th May 2024 - 02:14 PM |
