WTB: 74 1.8 AAR rubber elbow |
CoronaMike |
Jul 6 2020, 06:31 PM
Member Group: Members Posts: 152 Joined: 11-February 19 From: Maryville, TN Member No.: 22,868 Region Association: South East States |
StarBear |
Jul 6 2020, 06:58 PM
Senior Member Group: Members Posts: 1,885 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Yeah, same with me about a year ago. Go figure. Found some rubber elbow from a BMW or something that fit without crimping too much.
CoronaMike |
Jul 6 2020, 08:10 PM
jim_hoyland |
Jul 6 2020, 09:35 PM
Get that VIN ? Group: Members Posts: 9,298 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Pierside Parts in HB may have or get for you
(714) 848-8868 17031 Newland Street Huntington Beach CA 92647 United States Also, bus depot on-line |
cary |
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Mikey914 |
Jul 7 2020, 01:47 AM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We do ,
Thanks Cary |
CoronaMike |
Jul 7 2020, 08:39 AM
We do , Thanks Cary @mikey914 I actually just bought one of those - but it's not the same thing. That's for a 1.7 or 2.0 and it goes in a different spot. It has smaller openings. For some reason I didn't read the description when i bought it. BUT...I have one now just in case...? (IMG:style_emoticons/default/smile.gif) |
CoronaMike |
Jul 7 2020, 08:40 AM
Mikey914 |
Jul 7 2020, 09:18 AM
We do , Thanks Cary @mikey914 I actually just bought one of those - but it's not the same thing. That's for a 1.7 or 2.0 and it goes in a different spot. It has smaller openings. For some reason I didn't read the description when i bought it. BUT...I have one now just in case...? (IMG:style_emoticons/default/smile.gif) Feel free to drop it back I will issue a refund no problem. I will look at making these if I can't find one. I'll look around today and see if I can find one. I'll let you know. Mark |
StarBear |
Jul 7 2020, 11:22 AM
We do , Thanks Cary @mikey914 I actually just bought one of those - but it's not the same thing. That's for a 1.7 or 2.0 and it goes in a different spot. It has smaller openings. For some reason I didn't read the description when i bought it. BUT...I have one now just in case...? (IMG:style_emoticons/default/smile.gif) Feel free to drop it back I will issue a refund no problem. I will look at making these if I can't find one. I'll look around today and see if I can find one. I'll let you know. Mark @Mikey914 Mark - I may have kept my old, cracked one (for 1.8L) as a taped backup spare. If you'd like to use as a production guide, just let me know. |
JamesM |
Jul 7 2020, 11:30 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
We do , Thanks Cary @mikey914 I actually just bought one of those - but it's not the same thing. That's for a 1.7 or 2.0 and it goes in a different spot. It has smaller openings. For some reason I didn't read the description when i bought it. BUT...I have one now just in case...? (IMG:style_emoticons/default/smile.gif) What is the hose ID on the one that came out? The elbows I received from 914 rubber fit both the early and late AARs that i have around here (along with most other hose connections on my 2.0s and 1.7s. They do have to stretch a bit to make the connection but that is necessary as it needs to be an air tight seal. Per the 1.8 hose diagram that i have all those hoses from the AAR on a 1.8 should be 13mm(which these fit) only hose I see that is larger on the 1.8 is from the Decel Valve. Are you sure your hose routing is correct? |
CoronaMike |
Jul 7 2020, 01:23 PM
The connecting 'tube' that connects to the hose that goes to the air intake boot fits snug on one side - but I think the original elbow has a bigger opening on the Aux Air Reg side. I haven't tried to cram it on yet - but by looking at the old one - the opening looks considerably bigger. I'll have to see if I can get it on there. Here's a picture of the "engine crankcase breather elbow" from 914 rubber next to the actual part from the car. @mikey914 Thanks for the option to return. (IMG:style_emoticons/default/smile.gif) |
CoronaMike |
Jul 7 2020, 02:52 PM
@jamesM was right.
It's a tight squeeze - but this looks like it should work. Thanks everyone. (IMG:style_emoticons/default/smile.gif) |
cary |
Jul 9 2020, 09:21 AM
Mikey914 |
Jul 9 2020, 09:57 AM
On the way
Lo-Fi Version | Time is now: 17th May 2024 - 01:01 AM |
