Alloy Lug Nuts, How do you strip Off the black ? |
jim_hoyland |
Jul 9 2020, 03:43 PM
Get that VIN ? Group: Members Posts: 9,273 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
What’s the trick to get the black finish completely off ?
914Sixer |
Jul 9 2020, 04:41 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
If you want to make them shinny, get some buffing compound and get started. Lots of work.
Superhawk996 |
Jul 9 2020, 04:59 PM
914 Guru Group: Members Posts: 5,780 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Annodize can be stripped chemically - I had it done on a set of motorcyle rims prior to plating them.
I think they used Sodium Hydroxide if I recall. Maybe talk to a plating shop and confirm. |
sixnotfour |
Jul 9 2020, 05:05 PM
914 Wizard Group: Members Posts: 10,423 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
pete000 |
Jul 9 2020, 05:19 PM
Easy off Oven cleaner takes it off.
jim_hoyland |
Jul 9 2020, 06:07 PM
oakdalecurtis |
Jul 9 2020, 06:35 PM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Easy off Oven cleaner takes it off. That’s what I thought. Years ago I used easy off on another part per Bruce Stones recommendation. I bought a new can today and sprayed the nut, let it soak for an hour and washed them No dice ! I just held mine in a bead blaster, cleaned the black right off easily. |
jim_hoyland |
Jul 9 2020, 07:53 PM
HF $30.00 ? Would this do the trick
Requires a 1 HP compressor per their ad Attached image(s) |
Jul 9 2020, 09:44 PM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
HF $30.00 ? Would this do the trick Requires a 1 HP compressor per their ad That is a costly, messy way to remove some anodizing by the time you buy blast media.. What are you going to do once the black is gone. If you are going to powdercoat, the powder company will blast. If you are going to anodize, the anodizing company will remove the black and recoat. If you are going to paint, just scuff but paint doesn't last unless its epoxy or cerikote. If you are going to polish, don't bead blast, it will leave it rough and require a ton of sanding. If you are going to polish, you will need to anodize clear or it will cloud over. Might be cheaper just to buy new. What's the goal here? |
sixnotfour |
Jul 9 2020, 11:58 PM
jim_hoyland |
Jul 10 2020, 05:35 AM
Sweet ! (IMG:style_emoticons/default/smile.gif) I'llput those my wish list..... (IMG:style_emoticons/default/beer3.gif) |
DRPHIL914 |
Jul 10 2020, 06:21 AM
Sweet ! (IMG:style_emoticons/default/smile.gif) I'llput those my wish list..... (IMG:style_emoticons/default/beer3.gif) @jim_hoyland I thought you bought some already, - but it also looks like they have the open lug nuts in chrome as well as the closed. |
billh1963 |
Jul 10 2020, 06:23 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
horizontally-opposed |
Jul 10 2020, 10:03 AM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
This is the way to go... Had a set of old black alloy lug nuts stripped and re-anodized gray at an anodizing place a years ago after having the tops (but no threads) cut off. They came out looking terrible lined up on the counter but (fortunately) great on the car, where you don't see the color variance so much. |
Lo-Fi Version | Time is now: 8th May 2024 - 04:05 AM |
