Hidden Bolts During Transmission Removal, Which Ones? |
Ansbacher |
Jul 11 2020, 06:10 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Getting all my ducks in a row prior to removing my transmission soon. Of the bolts holding the starter and transmission to the engine, which ones need to be addressed from INSIDE the engine compartment? I am seeing multiple and conflicting answers when researching this.
Also, which bolts do I remove at the rear mounts- the single bolts at the center of each mount or the two bolts on the side of each mount? Confused... Lastly, is it possible to do this job on ramps, or do I need more height via jack stands. I do understand the necessity to support the engine during the process. Advice needed and thanks. Ansbacher |
Jul 11 2020, 07:01 PM
Resident German Group: Admin Posts: 41,614 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
For the rear, i find it easier to just unbolt the two small 10mm bolts on each mount so the mounts stay with the transmission.
As for the 4 case bolts, the only one that needs attention from inside the engine bay it the one on the top left (drivers side) that also holds the starter. Make sure you remove the ground strap and have good support for the engine before you try to drop the transmission. A ramp should be fine if you removed the rear valance, that should be plenty of room to balance the transmission on a floor jack and roll it out the back. (IMG:style_emoticons/default/smash.gif) |
Ansbacher |
Jul 12 2020, 10:59 AM
There is nothing like info from the horse's mouth. Thanks Sir Andy!
Ansbacher |
Lo-Fi Version | Time is now: 4th May 2024 - 10:41 AM |
