Engine ID number strange, Tell what engine this is |
Porscheracer1 |
Jul 11 2020, 11:02 PM
Newbie Group: Members Posts: 6 Joined: 9-July 20 From: Hills above Santa Cruz Member No.: 24,473 Region Association: Northern California |
Hoping someone can tell me what engine this is. Don't the replacement engine IDs have an X at the end? I need to look at the intake bolts too. There are no numbers next to the oil fill stand though.
I noticed the VW logo at the end. Did not see that before. |
914Sixer |
Jul 12 2020, 06:50 AM
On a Porsche engine the stamping location would make it a 1.7, 1.8 engine. However that number is not a stock 914 number. Thinking it is a miss stamped 1.8 engine that is should start with AN. We will need some pictures of the whole engine.
larryM |
Jul 13 2020, 03:10 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
not a listed Bus motor, but maybe other VW? other A.xx codes are in the VW mix
http://www.volksbolts.com/faq/eng-codes.htm https://davidplanella.org/vw-bus-engine-codes/#engine-codes |
Porscheracer1 |
Jul 18 2020, 08:12 PM
On a Porsche engine the stamping location would make it a 1.7, 1.8 engine. However that number is not a stock 914 number. Thinking it is a miss stamped 1.8 engine that is should start with AN. We will need some pictures of the whole engine. Hi, Well I was all ready for it to be a 1.7, or 1.8, BUT... It has 3 bolt intakes, and 94mm bore. Which makes not only the number strange, but the location of it strange as well... Attached thumbnail(s) |
SteveL |
Jul 18 2020, 08:16 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
Could it be a factory replacement case, that was not factory stamped? I've heard of that on American V8s.
Porscheracer1 |
Jul 18 2020, 08:22 PM
According to this from the sites referenced, it is not a recycled engine. It has the factory logo like the one pictured...
Porscheracer1 |
Jul 18 2020, 08:26 PM
So maybe two errors... ??? should be GA, not A, and the location should be under the oil fill tower.
914Sixer |
Jul 19 2020, 10:45 AM
GA 2.0L engines are stamped on filler neck not on block. Somebody took a case and built a 2.0 engine.
914sgofast2 |
Jul 19 2020, 11:43 AM
Senior Member Group: Members Posts: 616 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Might be a VW 411 or 412 motor that someone upgraded with 2 liter pistons and Porsche heads.
Porscheracer1 |
Jul 19 2020, 06:19 PM
Might be a 1200cc Beetle motor someone modded up?
http://www.volksbolts.com/faq/eng-codes.htm Only ones that have just an Axxxxxxx |
Lo-Fi Version | Time is now: 16th May 2024 - 06:25 PM |
